you wouldn't even be able to use the word map in a 7mgte, it just does not exist
there is the turbo pressure sensor located on the left strut tower, same side as your diagnostic box, it is not efi related in any way
so... 7mgte = no map sensor.. anywhere
unless you magically have a turbo A engine, but then then you wouldn't have an afm if you had one of those
