09-11-2006, 03:45 AM
#10
hardly ever do we get any broken down F bodys. the only comon thing would be fuel pumps and seldom transmissions, other than that look for leaky engine oil pans and leaky transmission pans, "any car can have this though".
When you get ready to buy,make sure that its shifting firmly and properly.. that would be my greates concern.other than that, camaros and firbirds w/the 5.7 are very reliable and trouble free cars.
here are all the "TSB" technical service bulletins that there are for that vehicle. If you need any help in the future let me know.
#01-07-30-032C Transmission Oil Leaking from Transmission Vent (Replace Transmission Case Cover Gasket/Channel Plate Gasket) - (Jul 26, 2006) #05-06-01-019D Engine Oil Leak at Crankshaft Rear Main Oil Seal (Install Revised Crankshaft Rear Main Oil Seal Using Revised Rear Main Seal Installer) - (May 12, 2006) #04-07-30-028A 4T65-E Automatic Transmission Fluid Leak from Reverse Servo Cover (Replace Reverse Servo Cover Seal) - (Jan 12, 2006) #01-07-30-038C Diagnostic Trouble Code (DTC) P0757 Set, Service Engine (SES) Lamp Illuminated, Poor Performance of Transmission, Transmission Slipping (Clean Transmission Valve Body and Case Oil Passages of Debris) - (Oct 12, 2005) #01-07-30-002E Malfunction Indicator Lamp (MIL) On, Transmission Stuck in Second or Third Gear, Instrument Cluster Inoperative (Verify and Repair Source of Voltage Loss in Transmission Solenoid Power Supply Circuit) - (Sep 23, 2005) #02-07-30-013E Incorrect Transmission Shifts, Poor Engine Performance, Harsh 1-2 Upshifts, Slips 1st and Reverse, Torque Converter Clutch (TCC) Stuck Off/On, DTCs P0757, P0741, P0742, P0730, P0756 - (May 20, 2005) #00-07-30-022C No Reverse, Second Gear or Fourth Gear (Replace Reaction Sun Shell with More Robust Heat Treated Parts) - (Dec 10, 2004) #03-06-04-030A Multiple Driveability Symptoms Due to Clogged Fuel Injectors (Clean Injectors) - (Jun 24, 2004) #02-06-01-038 Engine Knock or Lifter Noise (Replace O-Ring) - (Dec 2, 2002) #02-06-01-029 Needle Bearings Found In Oil Pan (Replace Rocker Arms) - (Aug 28, 2002) #01-06-01-023A Higher Than Expected Oil Consumption (Replace Rings and Engine Valley Cover) - (Jun 19, 2002) #02-06-04-023A Audible Spark Knock (Detonation), MIL Illuminated, DTC P0332 Set (Replace Rear Bank Knock Sensor and RTV Area Around Sensor) - (Jun 14, 2002) #02-07-31-001 Clutch Pedal Return Spring Breaks or Scraping Noise When Clutch Pedal Applied (Replace Clutch Pedal Return Spring) - (Feb 19, 2002) #01-08-57-009 Rear Floor or Trunk Wet on Top of Axle (Apply Sealer) - (Dec 17, 2001) #01-05-23-010 Noise/Rattle from Rear of Vehicle While Driving (Replace Rear Backing Plate Bolts) - (Sep 21, 2001) #01-07-30-021 Park/Neutral Position Switch Connector Cannot Be Removed (Replace Switch and Connectors) - (May 2, 2001) #01-08-42-002 Headlamp Door Squeaks When Opening or Closing (Apply Lubricant) - (Feb 28, 2001) #01-02-35-001 Steering Wheel Squeaks When Turning (Install Insulating Material) - (Feb 28, 2001) #01-08-48-001 Windshield Reveal Molding Squeak (Add Anti-Squeak Tape) - (Feb 14, 2001) #00-08-57-004 Water Runs Out of Front Lower Corners of Rear Hatch When Opened (Install Sealer) - (Nov 29, 2000)
