Thread: brake problems
Old 09-11-2006, 06:13 AM   #1
mrnickleye
mrnickleye's Avatar
Default Not a common problem
This problem is NOT all that common, in Supras or any car. It can happen, but usually the fluid leaks out between the master cylinder and the booster. It can be seen, and signs of the corrosiveness of the fluid, on the booster. Then, You can just replace the master.
Also, I have seen fluid dripping out of the booster at the bottom. Then I would recommend a booster change, as a future failure is coming.
Boosters, as an automobile component, are actually one of the longest lasting things on a car. For a part that is used / moving parts, so often in a cars life, I am very suprised that more don't fail.
After more years in the business than I care to say, and having done (or assisted with) more brake jobs than Midas (just kidding), I have only replaced about 4-5 boosters.
