you could probably take the parts from the n/a.(im not sure, im not a doctor)
1.transmission
2.flywheel
3.clucth disc
4.preasure plate
5.clutch pedal and brake pedal
6.drive shaft
7.engine to trans support wing
8.transmission cross member
9.manual tach
(make sure the clucth and flywheel are good because a turbo engine going through a non turbo trans is a little squrlie)
10.some say you dont need a manual ecu and some you do. idk about that
