Thread: 2JZ in an 85
Old 09-16-2006, 04:38 AM   #1
midwestmk2
midwestmk2's Avatar
Everything!!!!!! Unless you are full on certified mechanic with about 5 years under your belt or have completed this swap before then you shouldnt try it..There are other forums which deal with this swap..Go check out http://forums.celicasupra.com/ ..Just remember to use search..
