Make sure your TPS and CPS are set right. You have to use the ohmmeter to set the tps and you have to get the motor to top dead center for the cps. Is it a turbo? You may also just be leaking air. This happens a lot. Any black smoke? Also make sure your afm bleed screw isnt missing or something. Any kind of air leak after the afm will make it run rich, especially if its a turbo and its under boost. Give it a try!
