Make sure your CPS is timed right, Then use the tsrm and a voltmeter to check for correct resistance and output voltage on your 02 sensor, afm, tps, water temp senor, etc. Make sure all the sensors are correct. The slow acceleration is probably because the base timing is wrong. Does it smoke at all? it could also be a boost leak of some kind. Look for black smoke. And does it backfire? backfiring when you floor it can be the TPS set wrong. Oh and just fy cps = cam position sensor Tps = throttle position sensor AFM = air flow meter, mass airflow sensor, whatever you want to call it.
