Originally Posted by ogon
Hi,I`v got supra NON TURBO 2JZ about 5 monts and thinking to put Turbo Kit witch i found on EBAY but i do not know who can fit it,basically i can do it buy myself but do not wanna damege somethink.Does anyone know what mod. sould i do to fit this kit.........http://cgi.ebay.co.uk/2JZGTE-SUPRA-Total-Turbo-Kit-and-FMIC-INTERCOOLER-MKIV_W0QQitemZ250022979648QQihZ015QQcategoryZ72205 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem .........
Thanks
Fwiw, I agree with supra90turbo. You need to install a proper 2jz-
GE kit from a reputable seller, such as this one:
http://www.powerhouseracing.com/files/catalog.php?make=Toyota&model=Supra%20NA&catagory= Turbo%20Upgrades
Imho if you go with a cheap no-name kit off ebay, you're likely to find it's badly made, doesn't fit, doesn't come with all the parts&pieces you need, doesn't perform, and isn't reliable.
Besides all that, the kit you linked to is for an Mkiv Turbo 2jz-g
Te (not an normally aspirated/non-turbo). In other words, it absolutely for sure will
not fit your car. If you wanted to fit it you'd have to start by cutting that header apart, re-bending the pipes, and weld a 2jz-ge exhaust flange on it. You'd have to get LOTS of custom-bent pipes for your intercooler, and even then it probably still wouldn't fit right. Starting with this kit is not a practical option, imo.
