Old 09-20-2006, 12:41 AM   #1
mrnickleye
mrnickleye's Avatar
Unhappy possibly pump time
Sounds like the pressure valve in the pump may be sticking when the clearances tighten up due to heat.
You might try some cleaner fluid (for P/S from parts store) in there for a week and see if it helps.
If not, then don't just leave it in there, because if left too long, it will destroy the rack seals.
You may need a reman p/s pump. Carquest is between $135 & $235 (my cost & full list price)
