Old 09-23-2006, 12:34 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by onesicsupra
I havn't done it since i bought the engine about 8 months ago so i will try it, do you know what kind are the best for a supra?
If you want plugs that don't need to be changed very often, just get stock plugs (platinum) and gap them down to about .032". Note: be VERY careful about damaging the tiny center electrode while gapping platinum plugs...the slightest scratch, scuff, or 'nick' on the edge of the electrode, will radically reduce the service life of the plug.
If you want copper plugs that need to be changed about every oil change, NGK 6097's are ideal for a 'bpu' Mkiv tt, imho...also gap them down to about .032" (depending on the max boost you plan to run, how old your coilpacks are, and whether you have an ignition amplifier (eg. HKS DLI)). Note that copper plugs are MUCH easier to gap than platinum.
Life begins at 30psi.
