Thread: No spark!
Old 09-23-2006, 03:58 AM   #8
Isphius
Isphius's Avatar
And to help out, Change your spark plugs, Clean up the holes/threads they were in, Check your wires resistance(good idea to replace anyway), And make sure everything is plugged in (all sensors, grounds, battery, etc). And then test it by putting a spark plug in each wire, And hold the threads against a ground(make sure you hold it by the wire, not the plug or boot) and tell someone to crank the engine. Should make a nice blue spark. Check all the wires/coils that way
