Thread: exhaust setup
Old 09-23-2006, 05:28 PM   #6
Isphius
Isphius's Avatar
Any turbo is going to have a flange on the exhaust side. If you get the DDP, you can have the flange cut off and have a new one made that is the same flange as your turbo. The only openings that a coupler go on are the compressors intake/outlet. The turbine side has flanges with bolt patterns on the inlet and outlet.
