Old 09-25-2006, 11:24 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by onesicsupra
u.s. at the moment i have a jdm 5 speed turbo but i need a clutch pedal assembly to use it because im auto
Is there such thing as a jdm 5 speed turbo? Afaik, the 2jz-gte only came with the 6spd.
Also, why are you changing to the jdm engine? Is there something wrong with your current engine? ...or are you only swapping ecu's and if so, why?
You said "...first gear does fine but after that it starts popping like its not getting enough fuel...". Does it also do that when you put it back to oem sequential mode?
Please fill us in on all of the details of the Supra you're currently driving with the "popping" problem', including all of the modifications.
Life begins at 30psi.
