engine fitup in 85 supra
I beg to differ, the 5M, 6M, 7M. All use the same block so they will bolt right up to the tranny and the mounts are the same, the only thing you will have to do. if you put the 7m in you will have to change ecu and the wiring. the 6m from my research you will only have to change minor things. The other engines will require mods to the fram and chasis.
