Yes the 5,6,7m's all use the same blocks but the motor mounts do vary between models and years.The 1'2jz series motors on the other hand will drop in but you will have to fab your own motor mounts,tranny mounts,wiring,etc..You will not have to do any chassis or frame mods..
