Thanks suprra_girl, I also have two more questions
1. If you run a wire from the bad knock sensors connector to the good knock sensor and it stops the check engine light can you leave it like that or could it be harmfull to the engine?
2. Does the check engine light come on when the engine knocks or just when the knock sensor stops working?
