Old 04-26-2005, 05:40 AM   #2
mk3-drft
mk3-drft is on a distinguished road
A70 (wide body) supras have a offset of 44. factory wheels are 16x7.
A80 supras have a offset of 50 and come from factory in the following configs.
16x8
16x9
17x9
17x9.5
all A80 wheels are a bad idea on a A70 as the offset is different and even the thinnest A80 wheel is still 1" wider than the A70 wheel.
however a 5mm spacer on the front of a A70 will allow you to run A80 16x8 all round.
dont even think about fitting A80 16x9's to any corner of your A70 unless you plan on putting a overlander kit through it.
using a 17" wheel with a closer offset to 44 as possible will allow you to run wider rim than 8" but the best method is to have them fitted to the car and go for a drive including hard turns and full lock steering to make sure of clearances.
enjoy
mk3-drft is offline   Reply With Quote
