Old 09-28-2006, 03:58 PM   #2
supra1985turbo
supra1985turbo is on a distinguished road
Wink
I rebuilt my HKS T4 turbo the only problem I had was installing the compressor seal it was a little brass seal with a carbon fiber peice that had to be pressed into the back fo the compressor wheel plate, Need less to say I had to by another seal because I broke the carbon fiber in a bunch of little ity bity peices. I asked the guy that I got it from which he owns his own turbo rebuild shop, how I can install it with out a press, I asked if I could use a c clamp he said that would work and to use a socket that would only touch the brass not the carbon. It took a while but I got it. And make for damn sure you put everything back in its specific place and orintation!!! The rest of the turbo is easy as cake!!!!!!!!!!!!!!!
supra1985turbo is offline   Reply With Quote
