Originally Posted by mrnickleye
Not enough coolant flow thru the core. What thermostat are you running?? I use a 180* in the summer, and a 195* in the winter.
That 15* makes a lot of difference in the heater operation, but not in the overall engine temp, as it never get close to 1/2 on the gage.
That is because I'm using the heater, which cools the engine too.
stock??
what is the stock temp for the thermostat
mine is right below the midpoint
i have never had a problem with this in the past winters so i dont know what it is..
thanks for the info ddmcse, ill try that.
