stock thermostat is 195*. But that is also for emmision control. My VSV was bad, so I just hook the vacuum hose directly to the water valve in the winter, and remove (and plug with golf tee) in summer.
Hook the vacuum hose direct and see if heat improves.
180* thermo seems to be ideal.
