Originally Posted by Isphius
Its not your ECU. If your getting a code 11, Its a loose battery cable or ground. Check those out. The code 51 I believe is just your A/C switch or something like that. As for the poor running, Just get new plugs and wires. If that doesnt help, Start checking other things. Always do that first tho.
The plugs and wires are new, were replaced by my friend who was the previous owner, but just in case i will get new ones, what are the recomended kind....NGK Iridiums?
