Originally Posted by Spudboy
The one on the left is for your coolant level. If it's on all the time add coolant NOW to your overflow bottle. (sometimes in hard turns it sloshes to one side and tells the sensor it's low for a second)
The one on the right denotes one of your lights is burned out. Check your tail lights and break lights. Have somebody press the brake while YOU look. There are two (2) brake lights on each side (4 total) and if just one of the 4 is burned out everything may look almost normal but it's not and that sensor on your dash will tell you so.
thanks alot, where can i get some coolant?
