TEMS conversion?
Is it possible to convert a NON-TEMS equipped MKIII Supra N/A (1987) to a TEMS Equipped Supra? If so how would it be done? I have looked for instruction on how to do something like that as I heard the TEMS system is absolutly awesome. I can't see it being that difficult, just a bit expensive.
Also what is the benefit of the LS400 AFM. Do I have to get new injectors? if new injectors are needed what cc should I get?
*edit* Also does anyone know where I can find a stock wing (like the ones on the turbo models)?
Thanks guys!
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
