Originally Posted by mrnickleye
I'm not removing it for more power,the canister keeps filling with so much gas that it builds pressure and blows off the bottom rubber hose which then leaks gas all over my hot downpipe(very scary).I think it might be because the motor is running rich because of my bad knock sensor,but for now I took out the canister and ran the (to tank) hose that was on top to were the bottom hose went and plugged the (purge) hose.The car seems to run fine but if this will cause problems or if anyone knows a better way to run the hoses please let me know.
