Bump. Same question as above.
BTW for the coilovers versus TEMS, Coilovers are a helluva alot more expensive check HKS' out http://www.hksusa.com/products/?id=716&rsku=5281 where as to install the TEMS systems is $400. sooo im gunna go with tyhe tems system.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
