NA-turbo conversion
i am actually converting my 87 NA to a turbo. the best thing to do is buy a JDM 7m-gte. that is the cheapest,fastest and easiest way. but youre gona need all these stuffs: ecu, air flow meter, intercooler kit, oil cooler, down pipe, accordian hose and harness. the differential, driveshaft and tranny is optional. i suggest that you get a tranny for 7m-gte because you will mess up your NA tranny if you upgrade your turbo. the turbo tranny is called R-154 i believe.
