Old 10-05-2006, 12:09 PM   #14
pwpanas
Supra Owner
pwpanas's Avatar
Thumbs up
Originally Posted by onesicsupra
the guy said that the 5 speed has longer gear ratios than the 6 so that is why it is supose to be better...
That's not true either. Here are the ratios:
GEAR_RATIO_Between_V160 vs.
_____________Gears____W58
V160
_1____3.827
_2____2.36_____1.467____0.076
_3____1.685____0.675____0.056
_4____1.312____0.373____0.098
_5____1________0.312____0.095
_6____0.793____0.207
W58
_1____3.285
_2____1.894____1.391
_3____1.275____0.619
_4____1________0.275
_5____0.783____0.217
As you can see in every (!) case the gear ratio is longer in the 6spd.
...and my coilpacks are the same ones that came with the motor so around 80,000 miles
They may be overdue for a change, along with your "fried...vsv's".
Life begins at 30psi.
