The intake will take about two seconds to remove. Matter of the screw that holds the hose on the throttle body, and the bolt that holds the afm onto the side wall. As far as the manifold I am too big to even think about reaching all the bolts :-) 200 LBS 6'6", i dunno i could be wrong.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
