Old 10-06-2006, 04:39 AM   #1
mk111boy
mk111boy is on a distinguished road
Default problems problems problems
ok ive got a 1987 toyota supra turbo and when i start it it idle's fine but when i go drive it and it warms up the check engine light comes on (its a maf sensor code)and it will rev up and down to 2000 rpm with the gas peddle to the floor . As soon as it hits 2000 rpm in any gear it will do this. ive changed the maf sensor ,wiring harness, ecu ,tps sensor with ones from my other supra, im thinking it may be the egr valve or iac.
PS: it has a greddy blow off valve thats been rerouted to the intake pipe, hardpipe kit, full exhaust, and there is no leaks in the hardpipe kit
PLEASE HELP IM CONFUSED!!!!!!
mk111boy is offline   Reply With Quote
