it should be easy to replace. you have to take off the center console piece, the foglight/defog piece. take the top cover off, about 6 screws if theyre all there, take off the screws you see now that are going into the white part of the cluster. unplug all the connector behind the cluster and disconnect the speedo cable. now just pull out. be careful when you work around the speedo cable cus that tip will break easily. i broke mine last week.
My cars:
85 Trans Am- Ehhh- Gone
83 Rx7- Much Better- Gone
86.5 Supra- Love- Not Gone
