you can use part of this page to help you out
http://supra.co.nz/swap.htm
once you have all the screws from the other items undone you should be able to see all the screws that hold the cluster in
as you start sliding the cluster out you will need to unplug the harness as you go because you won't be able to pull it right out straight away
