Old 10-06-2006, 06:53 AM   #10
suprra_girl
7M POWAH! ;)
suprra_girl's Avatar
a) brand new doesn't matter, you may have put a clamp on crooked
but since this is only when it's hot (by which i assume you mean up to temperature not overheating)
check the tsrm with a voltmeter and go thru the checks for your air flow meter
it is more than likely a worn/broken/shorting wire in your engine harness not in the afm itself if it does it with a good afm also
Pics of my build.
Do a diagnostic first!
