Originally Posted by gomezmk
I normally run 10-12 psi
10-12 is to high for stock running. try running around 7-9 you should get ver minimal fuel cut.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
