Originally Posted by 84 celicasupra
i have a 84 supra i6 it will start and runs for 3-5 seconds and stalls out. if i try to restart it will not start unless i put a little fuel in the efi manually. i think it is a fuel pump issue.what is the best way to test the pump,and are there any othercommon issues to this problem? any help is greatly appreciated!
try to spray some starting fluid or some carburater cleaner to any open hose to the thorttle body and let someone start the car for you while you doing that.. and see if the car start or run while you spray the fluid... if you stop the fluid n a second later the car die again then i'm sure its your fuel pump...
