code 11
momentary interruption of power supply to ecu
you have crappy grounds
check the grounds on the intake manifold
unbolt them, check them, make sure they're still well connected, clean the surfaces, bolt them back on
make sure your battery terminals are good and not corroded
http://supra.co.nz/87tsrm/EFI/efi30.htm
