exactly
the engine itself may only cost an extra $200odd
but you're forgetting the rarity of the jz bellhousing > r154
then theres the wiring
changes of crossmember if you are pre 89 or buying aftermarket mounts
just buy same year engine & harness & ecu if you can and it should be all drop in
