Originally Posted by tone loc
i think its called a tiptronic and you can have your car in drive like an auto but if you want to controll it you put the shifter in a certain spot and there is + and - and you just move it up or down to change gears.
Youjust described steptronics. Tip is wht Formula 1 cas use.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
