Hello everybody, I think I might know what the problem is. My bov is leaking big time. I have a cheap bov that is very similar to the turbo xs bov. I changed the position of the bov so the boost from the 3000 pipe is pushing on the side of the piston instead up on the piston thus compressing the spring. It still leaks but not nearly as much as it did the other I had it routed. When I test drove it , it pulled amazing at high rpm but now it cut out 5,500 rpm instead of the usual 5,000 rpm. I'm hoping if I get a really good bov, it might fix it.
