Originally Posted by captwilddog
Ok guys i have a 86.5 supra and what i want to do is upgrade the injectors will a set out of a tubo fit it for it and will i have to change my computer are what can someone help thanks
uhhthe turbo's ijectors are the same size as the N/A. Secondly they will be old, so thats not good. No you will not have to mess with the ECU but you will have to increase the airflow. You can do this by doing the following:
1. Get a High-Flow Air Intake. I suggest the Spectre Airflow, or the K&N made for our cars. Both can ge gotten at your local Auto Store.
2. You must adjust your AFM. This is a really weird procedure. If you do it incorrectly you will have problems. You willhave to lean out the mixture. Go to
http://www.well.com/user/mosk/AFM1.htm.
And follow its directions. Read EVERYTHING before you do it.
My suggestion is shell out the money for bigger injectors.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
