Originally Posted by ravenmaster
When drainind tranny fluid from the plug on the bottom of the tranny, does that drain it all or just from the pan? If it is just from the pan how can i get it all out?
Good question I hope you get a result, I have the same problem drained about 2 to 3 litres out, made a big mistake and filled up with TQ Dextron III after a 5 mile run trany started to make a loud buzzing noise. Again drained out 2 to 3 litres and filled up with Dextron II, buzzing noise has gone but need to drain all the fluid out to make sure. The local auto shop recommended TQ Dextron III, totally wrong this is a different fluid used for the latest electronic transmissions. The trany holds 7 litres how you get the rest out I don’t know.
