Originally Posted by Isphius
Automatic transmissions work by shifting after your car falls out of its powerband, And it can tell more acuratley than you can, Unless you have a messed up transmission or a motor swap
..well said
Originally Posted by Supra2NR
it does launch you better than in D
no it doesnt...
having it in L (1) is the same thing as first gear in when in D...
except for you shift it when u want when in L, or1 ...which youll probably miss the powerband anyway. so its no better
