Thread: tail-light help
Old 10-19-2006, 01:24 AM   #7
hangsupra
Originally Posted by Murd
Hmmm... If you're getting current on the wire back there, you should be getting light. Make sure the plug isn't corroded in any way, and make sure it's getting connections where it's supposed to. I've had some where the back spring wasn't connecting properly, and some where the corroded plug caused a bad ground. Check to see how it's grounded too. If it's a ground wire trace it back and make sure it's grounded properly. If you can have someone press on the brakes, so you can see which wire is the hot brake wire.
i forgot to do that... let other people step on the brake n do the check wired... i need to do that... anything else i suppose to check...
