CHANGE THE HEADGASKET! The AFM should be fine, you might have to adjust the cog slightly.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
