Thread: Stalling Supra
Old 10-23-2006, 03:13 PM   #2
bigdoggbmx
bigdoggbmx's Avatar
bigdoggbmx is on a distinguished road
Default i kinda had the same problems
check befor all that your wire harness is ok that means that you have too strip all the tape off becouse the heat that is generated in that motor it makes all the wires briddle mine had six broken wires that threw codes that my maf was bad and my knock sensor and well you can see from there
if that is not the problem than check the TPS there pretty cheap if you need one and dont want too spend a lot there about 150$ new i have one ill sell you
hope this helps
bigdoggbmx is offline   Reply With Quote
