Old 10-23-2006, 05:13 PM   #4
ravenmaster
ravenmaster's Avatar
Location: Being not duly informed, I refuse to answer with any degree of accuracy for fear of prevaricating
ravenmaster is on a distinguished road
Removal of the gas tank IS NOT NECESSARY! Go buy a haynes manual, it will tell you exactly how to drain the gas. Anyway as stated drain ALL FLUID! and re-placee. the belts might look fine but re-place them anyway as well as any hoses in the engine compartment.
I bought m supra after a year of sitting in a GARAGE and everything looked fine but it turned out that the radiator hose badly needed replacement.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist View Post
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that.
ravenmaster is offline   Reply With Quote
