Thread: help please
Old 10-24-2006, 12:35 AM   #14
hangsupra
Originally Posted by my 1984 celica-supra
well I checked the oil and smelled no gas.the engine compartment does not smell like gas.I did find a bad gas cap replaced it and it still smells only when car is running.The gas mileage is probably around 23 mpg last i checked.It kinda smells like it is running way to rich.the car has 206,000 miles on it i guess i shouldn,t complain.I notice a little oil use when i start the car for the first time in the morning then clears up. I dont notice any smoke while driving though.it does not really smell like raw gas. I guess i will have to keep checking and maybe find something.
so it smell's like gas or oil...
cause this might be the few things... that you might need to check...
1. check the O2 Sensor...
2. check all the exhaust gasket... might have a leak...
3. check the vaulve cell
4. double on your exhaust pipe from header to muffler... might have little tinny hoe on it.. that you might not see...
5. check afm... try to adjust to stock position... maybe you run too rich...
6. check your head see if it burn oil...
hope this might help you little bit...
correct me if i wrong to alright... people...
