ok thanks for all the help i will start checking all that.And take care of any problems.I will let you know how i make out.
Originally Posted by hangsupra
so it smell's like gas or oil...
cause this might be the few things... that you might need to check...
1. check the O2 Sensor...
2. check all the exhaust gasket... might have a leak...
3. check the vaulve cell
4. double on your exhaust pipe from header to muffler... might have little tinny hoe on it.. that you might not see...
5. check afm... try to adjust to stock position... maybe you run too rich...
6. check your head see if it burn oil...
hope this might help you little bit...
correct me if i wrong to alright... people...
