Okay I am striaght u-p confused now. When facing the engine the intake tube and exhaust maifold is on the LEFT SIDE. Inside the exhaust manifold is the OXYGEN sensor. so if I am facing the car which side is the knock snesor and if it is on thje left side where is it in reference to the oxygen sensor?
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that .
