IF ITS TURBO IT SHOULD BE 650rpM AND n/a IS 700 DOES IT GO AWAY AFTER AWHILE? AND DO YOU HAVE THE STOCK INTAKE? SOME OF YOUR WIRES MIGHT BE MESSED UP CHECK ALL VACUUM TUBES.
1988 Toyota Supra Turbo Targa
Originally Posted by supramacist
Ya I'm the a$$hole. I think you're still mad raven cause I thought from your handle that you were a chick. I said I was sorry for that  .
