Thread: Broken Bolt
Old 10-26-2006, 11:27 PM   #2
mrnickleye
mrnickleye's Avatar
Default easy job
If the bolt broke when tightening it, and NOT when removing it....then you can use a small drill bit and an 'easy out' to remove the piece.
They aren't cheap, but I've had good success using 'left hand' drill bits, because the piece will often unscrew as you start to drill.
